Eureka G-Code
INCREASES PRODUCTIVITY, AVOIDS COLLISION ISSUES
What is Eureka G-code?
Eureka G-Code is a leading NC simulation software and a reliable digital replica for any CNC machine. Eureka simulates the actual G-Code sent to the machine, regardless of how it was created, manually, or post processed from any CAM system.
Thanks to 20 years of experience and development, Eureka G-code is able to emulate all the most popular CNC controls on the market: Fanuc, Siemens, Heidenhain, Haas, Fagor, Okuma, MoriSeiki, Mazak, Fidia, Selca, Osai, Num and many others.
Why Eureka G-code?
Because it allows you to have a digital replica on your computer of the machines you have in the workshop. You can do all the tests you want, quickly, without risk and without taking the real machine out of production.
Because it allows you to avoid the risks of damaging expensive workpieces, tools breaking and collisions with machine parts such as the spindle, caused by programming errors.
Eureka g-code is also useful for training new staff and allows you to work remotely. Programs for any machine and control can be prepared, simulated and verified even in the absence of the real machine.
Features & Benefits
  • Complete digital replica of the actual machine
  • Emulation of the same G-code running on the actual controller
  • Interfaces for most popular CAD / CAM systems
  • Additive and hybrid simulation
  • Simulation of tool change, head change and pallet change
  • Simulation of sliding head lathes and multi-channel mill-turn
  • Simulation of complex cycles and probing operations
  • Real-time collision detection and cutting conditions verification
Eureka G-Code Virtual Machine is compatible with the most popular CAMs
Eureka Private Cloud
Distributed simulation on remote server. Simply download the simulation files to a shared folder and let EurekaCloud do the job.
Production
Simulation of multiple workpieces, multiple pallets and multiple origins machining, including tool changes and piece probing cycles.
Multi-Channel Mill-Turn Machines
Simulation of multi-channel mill-turn machines running independent, synchronized or continuous 5 axes routines.
Training and Education
Eureka is a useful tool for the training of new personnel and for teaching ISO programming when no actual machines are available.
Result Analysis
Analyzes and compares the digital model with the machined stock, highlighting areas below or over tolerance.
Optimization
Analyzes the machining result to remove mistakes, decreases the production time and allows to generate time summary reports.
Eureka Mobile
Thanks to EurekaMobile any simulation made by Eureka Virtual Machining can be reviewed and analyzed anywhere on any mobile device.
Machine tool operators can now review the NC program simulation on their own mobile devices enabling an optimal machine setup. Potential critical issues flagged by the technical office can also be easily identified.
In addition to the 3D simulation of the machine movements, EurekaMobile provides a detailed analysis of any messages, warning and/or errors generated during the simulation. In case of collision, the colliding parts are highlightted in 3D to easily identify the issue.
The executed NC code, the used tool, the feed rate and other useful information are displayed as well during the simulation.
The EurekaMobile app is available for any iOS and Android device. A standalone Windows application is also available.
Download iOS
Download Android
Eureka Viewer
Any simulation can be reviewed and analyzed on Windows PCs using Eureka Viewer, available free of charge.
Ideal to be used in the shop floor or to share simulations with customers and suppliers.
